So im trying to firgure out what i need it to edit in the skin xml to change the range fof rhythm zoom for horizontel waveform so i can zoom in more or stetchout more anybody got any tips ?
geposted Wed 28 May 25 @ 8:12 pm
Why do you keep asking about the xml?, it isn't relevant
map a key, map a dial
zoom 70% ? zoom 30% & zoom_vertical 30% : zoom 70% & zoom_vertical 70%
geposted Wed 28 May 25 @ 8:31 pm
im talking about the level 0.0 to 1.0 for the zoom slider no matter what i set in the settings in never zooms in anymore or stretchout more thats what im trying to do im sorry not trying to be a pain
geposted Wed 28 May 25 @ 8:37 pm
try the button
geposted Wed 28 May 25 @ 8:49 pm
I have my controller mapped to control the slider but the view of waveform is still zooming out and in but i want more zoom in an the waveform to stretch i can get it to
geposted Wed 28 May 25 @ 9:01 pm
0.0 to 1.0 is the full range.
geposted Wed 28 May 25 @ 9:04 pm
Ok so is there some settings i may be missing because i used to be able to stretch out the waveform more i had to reinstall vdj it was like 6 months ago when could zoom more any advice on what setting in options could affect it ?
geposted Wed 28 May 25 @ 9:16 pm
Is there a setting other than rhythm zoom that maybe affecting the waveform beitng not as detailed and different length of waveform that i maybe have set wrong i use the shapes waveform
geposted Sat 31 May 25 @ 1:36 am
