I have my security on the right settings where if i load a song accidentally on the same deck where one is already playing it will give me a security message asking do i want to play it. Setting isnt doing its job!
geposted Mon 02 Jun 25 @ 4:06 pm
Was the song audible at the time you tried?
geposted Mon 02 Jun 25 @ 4:08 pm
There has to be an audible output on the channel you are loading the second track to for it to work.
Yes, so i never changed anything. I used to get a message saying "are you sure you want to stop this song". Now i get nothing. It just stops and loads the other song . I might try restarting my computer who knows. Im on the correct setting.
geposted Mon 02 Jun 25 @ 4:10 pm
This just started happening to me with the new version of 2026 and a Pioneer DDJ-SB2 which is overriding the load security. I'm in a bit of panic mode right now as I use this as a ceremony sound system. Any thoughts on how to fix this?
geposted Wed 04 Feb 26 @ 12:32 am
