Hi,
Is there a way to enable Virtual DJ 7 style automix editor where I can simply set entry and exit points for each song and disable cut mix from a deck without opening and browsing through POI editor?
I mainly use Virtual DJ software for broadcasting purpose and use automix feature for music and advertisement playback.
It was easy to set entry/exit points and disable cut mix from another deck while playing songs in automix on the fly with couple clicks but it looks like this is impossible with later versions of the software.
Any help will be greatly appreciated!
geposted Wed 04 Jun 25 @ 9:03 pm
geposted Wed 04 Jun 25 @ 9:05 pm
