Is there a way to script a button to toggle through saved audio settings and automatically 'apply' the setting, and then with each setting that is toggled through, can I associate a button color to each setting?
Why? I want to be able to quickly toggle between stereo and mono settings, and between different devices I use that have different sound setups.
geposted Sun 08 Jun 25 @ 7:49 pm
It is a setting so you could map a button to toggle between them I suppose
apply_audio_config "whateveryouwant"
geposted Sun 08 Jun 25 @ 7:55 pm
That's a good start. Now, if I only knew how to write a 'toggle' script...
geposted Mon 09 Jun 25 @ 2:56 pm
This will toggle between an audio config named Config 1 and another one named Config 2
If you want to toggle between more, you can simply add them
apply_audio_config "config 1" ? apply_audio_config "config 2" : apply_audio_config "config 1"
geposted Mon 09 Jun 25 @ 4:09 pm
Awesome, thank you Klaus.
geposted Mon 09 Jun 25 @ 7:29 pm
