I am experiencing an issue in which using a sample closes and reopens VDJ on a macbook pro. I have several sample banks and this only happens on 3 or 4 banks. the issue occurs consistently with the same sample banks. I have been using the same sample banks with no issue before this started happening. It happens if i click the sample on the software or use the sample pad on the controller. Can someone please help me identify and remedy this issue
geposted Tue 10 Jun 25 @ 2:53 pm
Seems like it might be related to pitchQuality, can you try with pitchQuality 3?
geposted Tue 10 Jun 25 @ 2:58 pm
I have isolated the issue to when i am using the blackhole 2ch virtual audio loopback driver
geposted Tue 10 Jun 25 @ 3:00 pm
