I Have an M4 2024 MacBook Pro . The issue that I have is after analyzing the songs VD doesn't give me the right BPM whereas I have on older 2019 MacBook Pro running the same version of VD smooth and perfect!
Does anyone has the same issue? if so what is the solution for it?
Thank you for your help in advance
geposted Thu 12 Jun 25 @ 10:39 pm
There's a fix for bpm detection on ARM machines in BUILD 8630 it's currently early access.
geposted Thu 12 Jun 25 @ 11:17 pm
