Dear Virtualdj team,
I'm a user with Cerebral Palsy disability and control my Virtualdj using a head switch. Everything is working perfectly as I've managed to create my own pads with stems and cuepoints together. I also use the four additional buttons for sound effects.
However, as you can imagine using my head makes it slightly challenging to accurate select buttons on the pads as they are assembled closely together. Is there a way of re-sizing the 8 pad buttons to make them a bit bigger and spaced out. This will mean I can mix more confidently without any fear of making mistakes.
Thank-you
Thank-you
geposted Fri 13 Jun 25 @ 1:32 am
Take a look at some of the skins designed for touch screens/tablets. They tend to have bigger controls.
geposted Fri 13 Jun 25 @ 8:31 am
Where are the skins located?
geposted Fri 13 Jun 25 @ 3:53 pm
You can look here, under 'downloads' or you can browse from within VDJ.
geposted Fri 13 Jun 25 @ 4:08 pm
