I'm considering getting the Pro Infinity ($299) license instead of the monthly subscription. Will I still need to login with my email or can I save the license on my machine so I don't have to login?
geposted Fri 04 Jul 25 @ 3:08 am
You still need to log in initially and then you can be "active" on two machines and as long as you don't log in to a third it will not need renewed. A file is left on your machine with the license to be checked by the software.,
geposted Fri 04 Jul 25 @ 5:42 am
If one were offline, could they be active on three machines?
geposted Fri 04 Jul 25 @ 11:47 am
Pretty sure the machine still needs to be online at some point to refresh the license.
There are no real reasons to keep a machine totally off the internet unless you're using a PC from 2002.
If that is the case you need to contact support who can provide a fully offline license separately.
geposted Fri 04 Jul 25 @ 11:51 am
i've often wondered this.....
so i have the infinity license, you say....
1 - I can load VDJ to as many machines as i want (would then be the free home version).
2 - If I wanted, I can register my license on 2 machines which VDJ will register their end.
- what happens if a third is registered out of curiosity (guessing the account gets blocked)
Question - the 2 machines that are now fully registered, if they are online (on the net) at the same time, do they have to be both on the same network? - I ask this as i often try to tether connections either by in house wifi or mobile hotspot.
geposted Fri 04 Jul 25 @ 12:11 pm
1 - Yes. The most recent two logged in will operate as Pro Infinity
2 - As above, the third machine (or older) will just be logged out, not blocked in any way
3 - No they do not need to be on the same network.
geposted Fri 04 Jul 25 @ 12:15 pm
