Can't clear/remove Search for.txt Files in vdj
geposted Fri 04 Jul 25 @ 3:13 pm
I've tried several times to clear the list out of search for.text file. If I select all and remove it does but as soon as I go back it's all back again ?
geposted Fri 04 Jul 25 @ 7:22 pm
u have txt in fileFormats setting in VDJ OPTIONS ?
If so, remove it.
If txt files are in your Search DB, u need to remove them.
Easiest way, create a Filter Folder as following..
-Select All files in that Filter Folder (CTRL+A)
- Right click on any of the selected files, from menu choose .. Search DB->Remove from SearchDB
If so, remove it.
geposted Sat 05 Jul 25 @ 4:45 pm
