Since updating to the latest version i have no sound in the BPM Editor. No playback or metronome.
geposted Sun 06 Jul 25 @ 10:54 pm
Works fine on my end (MacOS v2025-m b8663). What does your audio config look like?
geposted Sun 06 Jul 25 @ 11:09 pm
geposted Mon 07 Jul 25 @ 12:56 am
So I quickly checked this out usong v2025-m b8663 with the following audio setups:
They all worked. The first case asked if I wanted the preview to play over the master output (which is expected, as no dedicated headphone output was provided).
Seeing that your audio setup looks like the default for the controller and it has a dedicated headphones output, it should work there too, so I'm not sure - it might be something with that particular controller's audio setup (the devs would have more info).
- master (to the built-in soundcard)
- master + headphones (both to the built-in soundcard over the same channels)
- master + headphones default setup of a DDJ-1000
geposted Mon 07 Jul 25 @ 2:52 am
