For example, click DomKick in the Loopmasters sampler bank in the SAMPLER window and check the volume level, then click the same sample using the the pads section. The volume is lower. This is an issue when using stem swap as the sample volume is not as loud as the track it's being mixed in with. Is there a solution to this?
geposted Mon 14 Jul 25 @ 3:53 pm
