Guys I HATE that after a Windows Update or a re-start I have to re-sign in, and go to email to click on stupid link.
I HATE it.
This is not progress.
M
I HATE it.
M
geposted Wed 16 Jul 25 @ 8:39 am
This has happened to me too despite only having one PC on the license.
Same issue with getting logged out of the forum web page randomly too.
Seems to have started happening recently and it is bugging to say the least. Never ever had this issue before. I previously had two machines logged in permanently and never had to change anything.
geposted Wed 16 Jul 25 @ 8:57 am
Were these changes in the changelog, no they weren't.
geposted Wed 16 Jul 25 @ 9:05 am
Well that's strange as it's not happening here. I'm visiting the forum regularly, and running VDJ on two separate computers, but no issues with logging in.
Both the forum and VirtualDJ (on both PCs) open and run just fine, with my account remaining logged in.
geposted Wed 16 Jul 25 @ 9:09 am
I HATE it.
M
I HATE it.
M
And you're using your license on only TWO systems ?
geposted Wed 16 Jul 25 @ 9:17 am
Yes it's strange hence the reason it's being highlighted.
I have two separate licenses with only my home PC on one and my DJ machine and backup on the other one so they technically should never be logged out.
I'll keep a closer eye and if it happens again I'll report back, although my previous thread about constantly getting logged out of the forum never went anywhere.
geposted Wed 16 Jul 25 @ 9:39 am
What I'm getting at is, it's unlikely to be a VDJ issue, otherwise we'd all be seeing it...
I'm on the latest version too.
geposted Wed 16 Jul 25 @ 9:44 am
There were other users on the Facebook page reporting they were being randomly logged out so it's definitely something that needs investigated.
Wouldn't be great turning up at a gig with no internet connection and suddenly finding your machine has logged out for no reason.
geposted Wed 16 Jul 25 @ 9:47 am
I HATE it.
M
I HATE it.
M
Yes, I don't mind the systems thing, it's the logging out in back in again.
Hello,
You have asked to connect VirtualDJ with your email mike@celticprodxxxxx.xxx
Please follow this link to continue:
https://virtualdj.com/confirm.html?link=UyaRxxHh5ZxxxxFn57b0f
(if you didn't ask for this, you can safely ignore this message)
___
Thank you,
VirtualDJ Team
geposted Wed 16 Jul 25 @ 9:53 am
That's just a matter of having a backup license file on the computer, so if you ever do find yourself logged out at a gig (which should only occur if you've logged in on too many computers) then you put the license file back in the folder where it needs to be be.
If the venue has no internet, then VDJ would not be able to check online when it runs, so it would use the license file.
For the license file to be missing, VDJ would have to run, have internet access, see that another computer had logged in, then delete the file.
geposted Wed 16 Jul 25 @ 9:55 am
But people don't know that and shouldn't have to do that if things just worked.
geposted Wed 16 Jul 25 @ 9:57 am
But people SHOULD know that, and be prepared, because that's the way the licenses have worked for years now.
geposted Wed 16 Jul 25 @ 10:02 am
Really, people should know where the license is kept, which file and in the now hidden home folder?
Yes we are experienced users who know this but everyone else?
Most users just switch on their PC and rightly expect everything to work, as it should.
geposted Wed 16 Jul 25 @ 10:04 am
Yes, if they want to ensure that they'll never run into the issue you mentioned.
IMO the VDJ license system is well designed to prevent that ever happening anyway (see above).
I think dublinmike's issue is different anyway, because he's running multiple computers, in multiple venues, each (he says) with its own separate Pro license - and yet he's getting flagged by VDJ (presumably on his subscription account) due to logging in to too many computers.
geposted Wed 16 Jul 25 @ 10:28 am
The systems (PCs) thing matters. It always did. If you log in on a THIRD computer then the FIRST one will log out. That has always been the case and pretty much that's what seems that has happened here as well.
geposted Wed 16 Jul 25 @ 10:29 am
Hi ,
No on this account it is two machines, both were renamed causing the issue, I've resolved that using the computers tab beside licenses.
I've always been aware of the two computers limit, and I do things by the book.
My issue NOW is being logged out after a restart and having to use an email link to get back in again.
cheers
M
cheers
M
geposted Thu 17 Jul 25 @ 6:27 am
If you get logged out every time it means there's some write permission issue with the VirtualDJ folder.
If it's the entire folder that has the issue, then you would also experience issues saving lists or settings.
geposted Thu 17 Jul 25 @ 6:30 am
Hi Adion,
Thanks for you reply, to make sure I'm understood correctly: I'll have to try again. I'm only logged out after a Windows Update or a Windows restart, "remember me" is selected. ( the 4 PCs registered issue is resolved and is unrelated).
What pains me is that my machines are remote, so sometimes that 2 factor authentication email that you send does not result in a log- in. ( I'll include the email below). It means that I have to install Chrome and log into my email on the remote machine to log back in successfully, a security risk! It won't work to log in using the email link from my studio.
I really don't want two factor!!!!
I have no read/write restrictions on the VDJ folders at all. Neither Documents/VirualDJ or users/name/appdata/local/VirtualDJ they're being read by VDJ all the time.
Perhaps the issue comes from that being remote machines on my clients networks, I am obliged to update Windows for security reasons whereas normally i would blank those updates and kill them with GPEdit.
VDJ Two-Factor email:
Hello Mike,
An unknown IP from United Kingdom is trying to log into your account: 81.130.xxx.xxx
If it was you, click on the link below to confirm:
https://virtualdj.com/confirm.html?link=NfrUSGWZ6XXXXXXX537d4
If it wasn't you, please change your password immediately.
___
Thank you,
VirtualDJ Team
NOTE: That machine is running since 03 January on that IP address it is NOT unknown.
Can i opt out of two-factor or revert to a previous version?
Cheers M
Hello Mike,
___
Thank you,
VirtualDJ Team
Cheers M
geposted Thu 17 Jul 25 @ 7:37 am
Where are these PC's exactly?
geposted Thu 17 Jul 25 @ 7:48 am
