I have a novation launch pad and am slowly moving all the video functions to one page. All good so far, I can jump back and forth video sources (shader -> camera -> spout input etc). LEDs work, it is actually pretty good.
As a bonus I would like to programme a pad so that when camera is the source, that pad will step through the camera sources (internal -> web cam -> OBS etc).
I have tried
Any suggestions? @locodog ?
I have tried
video_source_select "camera" & effect_slider 2 0%to test whether I can simply jump the camera back to the first source, it switches to the camera OK, but doesn't change which camera is selected. I also tried explicitly naming the camera source
video_source_select "camera" & effect_slider 'Integrated Camera'. Nothing I have tried works.
geposted Thu 17 Jul 25 @ 12:53 am
you're calling slider 2 of slot 1. For AOV slot specify as such.
effect_slider audioonlyvisualisation 2 0.5
geposted Thu 17 Jul 25 @ 1:52 am
That's awesome (but obscure), thanks. Is there a way to count how many cameras there are so a pad press increases the value by 1 / (number of cameras)? That way a single press will jump to the next camera.
geposted Thu 17 Jul 25 @ 2:13 am
get_effect_slider_text audioonlyvisualisation 2 & param_cast int
geposted Thu 17 Jul 25 @ 2:22 am
