Tried it on two laptops. It stopped working since last 4 or 5 early access. Not noticeable unless auto bpm match is outside of range.
geposted Thu 17 Jul 25 @ 5:48 pm
Can you describe in more detail? Seems to work fine here
geposted Thu 17 Jul 25 @ 5:59 pm
Autobpm is on (range 8%) and smartplaylimitpitchrange is off.
Song playing on deck 1 is 90bpm for e.g.
Now load a song on deck B out of the 8% range e.g 110bpm.
VDJ should sync songs even if the selected range is more than the 10% difference, as long as smartplaylimitpitchrange is off.
geposted Thu 17 Jul 25 @ 6:55 pm
Is autoPitchRange on as well?
geposted Fri 18 Jul 25 @ 3:55 am
Missed that one. Seems the update selected off..Thank you.
geposted Fri 18 Jul 25 @ 10:33 am
