Hi,
I recently picked up a Kontrol Z2 to compliment a DVS setup. The controls are all working as expected but there is a minor but annoying issue. Each time I press one of the pads or buttons on the Z2, the LEDs of all the pads and buttons flash. In the device specific instructions there is reference to a custom template to be applied in Controller Editor but it seems this does not exist anymore in the plugins database. I have tried manually updating all buttons to "trigger" in Controller Editor but it doesn't seem like this is having any effect. I suspect VirtualDJ is already handling the lighting natively these days as the instructions are quite old. Any ideas to prevent all of the leds blinking when hitting a pad etc?
Thanks!
Thanks!
geposted Fri 18 Jul 25 @ 1:32 pm
