So what I want to do:
Simply enable a loop during playback without the interaction of VDJ changing how many bars the loop is or quantize. And be able to call the very same loop with the same length later.
BUT:
I set a loop of two bars and runs it, if doing a reloop later in the track the loop length will be changed to the loop setting number.
As fas as I can see, all the "smart" loop settings are turned off in settings.
Any advice?
BUT:
Any advice?
geposted Fri 18 Jul 25 @ 1:59 pm
