I'm at a loss here. Been reading and watching videos for days on this. On my Rev 7 controller I want to disable shift_jog as when I am scratching on the left deck and use shift + 2ndary function for whatever, my scratch track starts skipping. I want to disable this functionality. I've replaced the action portion of the SHIFT_JOG with the word nothing, saved it, but it doesn't work. It seems like my custom mapping is being ignored.
Thanks
Thanks
geposted Sun 20 Jul 25 @ 4:03 pm
How do I get rid of this? It's really screwing up my workflow.
geposted Sun 20 Jul 25 @ 4:07 pm
Change the SHIFT key script to just shift and then change SHIFT_JOG to nothing
geposted Mon 21 Jul 25 @ 8:20 am
It does not work. Can someone try this on a rev 7? I've edited the action setting of shift_jog and deleted everything and put in the word nothing and saved and it keeps coming back. I'm going to end up returning this rev7 if I can't get this fixed.
Please, help. I'll pay someone to help me fix this. PLEASE!!!!!!!
geposted Wed 23 Jul 25 @ 1:53 am
If it "keeps coming back" it means that your edits don't save. And this has nothing to do with the controller itself.
Are you using a MAC computer ?
Have you checked that VirtualDJ has all necessary permissions ?
If you change some random software setting, does the change stick, or it's lost after a restart of the software ?
geposted Wed 23 Jul 25 @ 8:20 am
It's not a mac, it's windows. I'm using win 11 pro and using an account that has full local admin privs
geposted Wed 23 Jul 25 @ 8:57 am
Be sure that ater you make an edit, you're using the edited mapping and not the default one.
geposted Wed 23 Jul 25 @ 10:37 am
How do I ensure that just go to shift jog on the left and then on the right choose the custom mapping?
geposted Wed 23 Jul 25 @ 11:12 am
