Hi, will be a cool thing can set a beat anchor with script,
now we have alternative of this, throw beers, but think it must be native option.
Other way i was imagine, could be editing database.xml.
to be honest don´t think it will be the solution, and have to recognice i haven´t knowledge or skill to do it.
thanks for support.
thanks for support.
geposted Tue 22 Jul 25 @ 5:20 am
set_firstbeat
geposted Tue 22 Jul 25 @ 8:36 am
thanks for triying, maybe you don´t understand the difference between first_beat and beat anchor,
i will try to explain to you.
first_beat only can be one.
beat anchor could be 2..3..4..or more...
usefull when bpm isn´t constant or the song break 16-32 pattern.
Regards!!
From my ignorance can´t undrestand why we could set mixerpoints or loadpoints but can´t set beatanchors points.
VD is by far the best software, have a lot of features than other softs... i´m sure it can be doit....
Regards!!!
Regards!!
Regards!!!
geposted Tue 22 Jul 25 @ 9:10 am
I get what you mean. For this I use the
reanalyze_multioption. The grid is often set right then with the markers you need and you can rearrange/adjust the beatmarkers in the poi editor when you need it.
geposted Tue 22 Jul 25 @ 12:44 pm
Sorry for delay, i really appreciate this tips, but isn't new for me, I'm not expert scripting, but try to learn and use all of options and verbs who this great software bring us. So my desire is exactly what I described.... A script for set_beatanchor. And if was possible other one for correct grid pattern for fix when song breaks the 32-64 beats patron.
Regards!!
Regards!!
geposted Fri 25 Jul 25 @ 9:53 pm
I usually just create a custom loop between 2 cues and the save the loop. I don't know if this is what you're looking for.
geposted Wed 13 Aug 25 @ 5:06 pm
Hopefully this will not be needed, because a new beat grid analyzer is in the works.
As usual, no ETA is available, but as I understand it, Atomix has been working on it for some time already,
geposted Wed 13 Aug 25 @ 8:52 pm
I think there will always be a need for manual touch up.
One way it could be done which is close to the current way the bmp editor works is by adding a tickbox that will set a beatanchor "firstbeat" of a whole 16 or 32 beats phrase, instead of only the 1 of 4 beats available right now.
Another way would be to allow the mouse to edit the phase, similar to what is currently done for bpm. ALT-leftclick could be used to move the grid around without stretching it and fix issues arising from complex rythms and irregular phrase structure (missing or extra bars) common in latin or african music.
geposted Thu 21 Aug 25 @ 5:06 pm
