Updated to v2025-m b8678 (Mac)
Key mapping for CTRL+UP should be:
deck 1 key_move +1
Used this mapping for several years and would work at all times, now only works when I manually click the cursor on the specific deck and use shortcut. How do I fix this behavior to function, no matter where the cursor is? (i.e. browser)
deck 1 key_move +1
geposted Sat 26 Jul 25 @ 1:06 am
Bump!
geposted Sun 27 Jul 25 @ 8:28 pm
While focus is on a list, some default list shortcuts take precedence over keyboard shortcuts.
These are CMD+A, DELETE/CMD+BACK, UP and DOWN.
I guess it could indeed be a little more relaxed regarding the combination of CTRL+UP/DOWN since those have no function in lists.
geposted Mon 28 Jul 25 @ 4:41 pm
Is this a functionality that was changed in a very recent update? Never had this problem until updating.
geposted Tue 29 Jul 25 @ 6:09 pm
Yes, a bug was recently fixed that prevented this to work as intended
geposted Tue 29 Jul 25 @ 6:15 pm
Is there a workaround to return to normal behavior? I guess I can always return to the older version if need be.
geposted Wed 30 Jul 25 @ 10:42 pm
Checking in to see if there's been any update to this; or a way around it.
geposted Tue 12 Aug 25 @ 4:28 am
Should be fixed in current Early Access release
geposted Tue 12 Aug 25 @ 4:32 am
Great news!
geposted Tue 12 Aug 25 @ 9:13 pm
Updated to the early release b8706. Works great. Thank you.
geposted Tue 12 Aug 25 @ 9:23 pm
