Vdj is not connecting to my tidal account even when I follow the prompt and log in!!
It has worked for a year and suddenly stopped!!
geposted Sat 26 Jul 25 @ 7:21 am
PC or Mac?
With or without DJ Extension?
I'm using a Mac and Tidal + DJ Extension with no problems.
I have an offline Cache with over 500 tunes built up over the last year, and all still work fine.
geposted Sun 27 Jul 25 @ 6:11 am
I'm having this issue on my Windows 7 desktop with Build 8336. I have some really cool old skins that don't work right on my newer laptop, and I have a mixer that uses firewire I wanted to try. The Tidal login says on the browser that it worked, but then in VDJ on the desktop it says Login Failed. I checked the host file in that Windows Etc folder, and it looks fine. I also checked firewall permissions. Maybe Tidal just won't authenticate on older VDJ anymore? It's been a long time since I'd bothered with VDJ until just recently when trying to get better sound on the new Denon gear. In the meantime, I will go back to the laptop.
geposted Sat 26 Sep 26 @ 7:05 pm
Maybe it's the age of your OS that's the issue. Can you log in to Tidal in any other software with Windows 7?
geposted Sat 26 Sep 26 @ 7:28 pm
Yes, no problem in browser or in the Tidal app on the desktop computer.
I also notice now that VDJ 2020 on the desktop won't even download tutorials or new skins & mappings.
I am clearly logged into my VDJ account within VDJ 2020, though.
geposted Sat 26 Sep 26 @ 7:40 pm
