i have a problem with virtual dj, everytime i broadcast
and switch songs with vdj i get this very wierd crackling sound.
i'm on windows 10
Processor AMD E1-1200 APU with Radeon(tm) HD Graphics 1.40 GHz
Installed RAM 8.00 GB (7.59 GB usable)
Storage 466 GB HDD WDC WD5000AAKX-083CA1
Graphics Card AMD Radeon HD 7310 Graphics (369 MB)
Device ID D3DE912A-1D1D-467B-8C6F-8C3E714BF65D
Product ID 00326-10000-00000-AA169
System Type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
wonder if anyone could help
i'm on windows 10
geposted Sun 27 Jul 25 @ 5:37 pm
Your machine barely meets minimum recomended specs, and may be below it in terms of the CPU, as that particular CPU is a very weak one. There is probably nothing much that can be done oyher thathan backing off performance heavy operations/settings
Realistically though - I would say you should invest in a better machine, using the page above as a baseline (and probably getting at least 16GB of RAM), because you'll most likely jit a performance wall on a lot of things.
- Does the problem still happen if you don't broadcast?
- Maybe increase the latency setting?
geposted Sun 27 Jul 25 @ 5:48 pm
I agree with DJ Vinyltouch - Your setup looks below minimum spec, although if it's only doing it between switching songs - Have you tried playing with the song load priority setting?
"songLoadPriority" is the setting name
geposted Thu 31 Jul 25 @ 10:57 am
