my shortcuts aren't working, even with the "search by first letter" in "no" it still go to the search bar when I try to use the keyboard
geposted Tue 29 Jul 25 @ 7:37 pm
by default the shortcuts you create are a combination of ALT and the letter you selected.
To just map a letter without ALT you need to go edit the mapping in the advanced view
geposted Wed 30 Jul 25 @ 6:15 am
