i remember there is a way to have the comment field appear on the deck under the title.
The XML to be changed through notepad.
Does anyone have the text that needs to changes, and how to save it so it works properly?
geposted Thu 31 Jul 25 @ 5:06 pm
If you use the "Blocks" skin by DJDad you can select what you want to appear yourself with no modifications.
geposted Thu 31 Jul 25 @ 5:13 pm
On the default, I could write you in a click toggle or even automatic time toggle [5 secs artist, 5 secs comment] If you want it send me a pm.
geposted Thu 31 Jul 25 @ 7:29 pm
The topic is close enough, I would add this question. Is it possible to display only one line of the comment field, maybe only the second line ? Maybe using the \n char?
geposted Thu 31 Jul 25 @ 8:04 pm
@Yan Duval not really, substrings are difficult to do with vdj.
geposted Thu 31 Jul 25 @ 8:49 pm
Thanks
geposted Fri 01 Aug 25 @ 10:28 am
