Hi all!
There is someting I'm unable to do, I wonder if there is a special trick to solve this.
I'm unable to fix phrase beginnings apart from the first one. The problem appears quite often when there is a long break in a song: they will make it last only 7 bars instead of 8. The phrase counter will be one phrase off for the rest of the song
I tried to add a Beat Anchor, but I'm only able to adjust the BPM after, not the phase. I was hoping to ALT-rightlight and drag the grid to change its phase, or something like that.
Otherwise, there is already a 1 of 4 beat check box. There could be a 1 of 16(or 32) to reset the phrase counter.
Any way it can be done now?
Thanks!
Thanks!
geposted Thu 31 Jul 25 @ 8:16 pm
I have a windows plugin to add beat anchors so for over runs I place 32 over the extra bit to keep it on the 32, under runs are rarer I add 4 or 8 or whatever at the end.
geposted Thu 31 Jul 25 @ 8:52 pm
Thansk for sharing this interesting solution.
geposted Fri 01 Aug 25 @ 10:42 am
