My karaoke songs are all in seperate ZIP files, there is more then 10K of them, the software doesnt pick them up when searching is there a way round this, other than extracting all before on the hard drive
geposted Fri 08 Aug 25 @ 2:09 pm
Is it a matter of just getting those when doing Search ?
If you navigate to the actual folders within VirtualDJ Folders List, do you see those zip files and load/play as expected ?
Your zip files are mp3+cdg ?
Do you have showZipKaraoke setting enabled in VirtualDJ OPTIONS ?
geposted Fri 08 Aug 25 @ 2:53 pm
