hi all.. probably i've found a bug on using clouddrive.
can someone check or tell developer to investigate? because i can sync my library on clouddrive
when i upload on clouddrive 2 or 3 playlist and about 100 songs i don't have problem.. but when i try using all my entire database and playlist it doesn't work
i use vdj and clouddrive to sync all my playlist on "mylists" (about 170 playlist +1 of all my itunes library about 35k songs and 250gb of data) on clouddrive (using google 2tb drive)
when i upload all it works.. but when i try to sync on other pc it doesn't work..
i explain better: i upload the "mylists"and subfolder on clouddrive.. and i can see all correct on clouddrive and on 2nd pc..
but when i try to download on 2nd pc it doesn't work.. i can only try to download a single list.. and when i try to download the itunes library playlist of 35k songs its not give me the option to download.. probably there a bug using more than 30k?? songs
because the procedure work well with small folder or playlist.. but when i use big numers it doesn't work..
do anybody have same problem? how can i solve it?
if it necessary i will do video of the problem.. let me know thankss
geposted Sat 09 Aug 25 @ 1:10 pm
