I have a question that maybe you have an answer for. For months now after I close VDJ, and then try to start it again I am told it is already running. When I check task manager it is indeed running. But it does not work nor can I get it to boot up without force stopping it.
This is on Windows
This is on Windows
geposted Wed 13 Aug 25 @ 4:46 pm
Usually related to some hardware device not released properly , could be sound card or/and some MIDI device. I am afraid you will have to troubleshoot and step-by-step find the device that causes this issue.
geposted Wed 13 Aug 25 @ 4:53 pm
Yes, I get the same thing regularly here. Sometimes the process even refuses to close in Task Manager.
There are no external audio interfaces connected. No DJ controllers. No other MIDI devices.
geposted Wed 13 Aug 25 @ 5:28 pm
I also have had it not be able to terminate via Task Manager.
geposted Wed 13 Aug 25 @ 7:52 pm
