My app quit on me multiple times yesterday after the update and it was embarrassing. Every time I went to load certain records it would just quit. WTH is going on with you guys? Ive tried reseting the app, updating the driver and nothing is working. Y'all are about to make me leave this app if I can't trust it.
geposted Fri 15 Aug 25 @ 10:38 pm
- What version did you update to?
- What's the specs of the laptop and what OS are you using?
- Did the application restart automatically or no?
- Were you online?
Probably good to list the songs you are referring to as well.
geposted Fri 15 Aug 25 @ 10:45 pm
I'm running the latest version of Sequoia....Yes it restarted and went to a default reset that didn't give me enough time to pick up another record to cover the shut down. There were multiple songs. It also happened when i attempted to use the mouse pad to load or search for a record.
geposted Fri 15 Aug 25 @ 11:10 pm
Yep not sure what to say (I use the latest build on two different machines running Sequioa with no issue).
If you were online maybe the devs have more info about the crash and what was happening applicationwise.
geposted Sat 16 Aug 25 @ 12:25 am
Thanks for your help
geposted Sat 16 Aug 25 @ 12:44 am
