I added an own window to the PRO skin.
On my may I have 3 screens attached
- the main screen (5K) with Virtual DJ
- a second screen (4K) displaying the video fullscreen
- a third "half" screen (1920x540), which I want to use as a controller screen
My window should be located on the controller screen.
I can move it there and it stays, but sometimes it gets messed up (moved out of sight, resized)
I already added a menu item with
Is there a possibility to set the window fix to this screen with a script?
I would like to add another menu item which positions the window at x=0;y=0; on "Screen 3"
Is this possible? Are there any possibilities to query and set Screen number?
setting_reset skinwindows(copied from DennYos "Controller 2020" skin) to reset the windows position and size.
geposted Sun 31 Aug 25 @ 3:41 pm
