When sending out NDI and in preview window on VDJ, it sends standard out 720P. When I switch to floating window, the resolution goes up over NDI as well. Is there a way to witch to different resolutions over NDI while still in preview mode on VDJ? Upgrade to full 1080P would already be great. I know this is a thing with bandwidth and so but on my M1 and M4 this is not any issue.
geposted Fri 05 Sep 25 @ 10:55 am
I think it should follow the recordVideoResolution option in that case
geposted Fri 05 Sep 25 @ 11:19 am
Did not know that, going to try this out! Thanks
geposted Fri 05 Sep 25 @ 2:27 pm
YES! That is working. Solved! Cheers Barney
geposted Fri 05 Sep 25 @ 2:31 pm
