Topic: Numark Party Mix MKII
trying to configure V-DJ for wired headphones on the Numark PARTY MIX MKII. I can get CUE in headphones (CUE in left channel,) but no MASTER in headphones. Not using external speakers, need to do all mixing in headphones.
MASTER > Party Mix MKII (WASAPI) > Channel 1 & 2
HEADPHONES > Party Mix MKII (WASAPI) > Channel 3 & 4
Switching the headphones to any other channel kills any CUE audio in headphones. I've tried ALL the options given, but no luck. Any suggestions are appreciated.
geposted Sat 20 Sep 25 @ 3:34 pm
MY APOLOGIES on my delayed response. This past month has been busy and I still need to resolve this. I've updated the driver for the controller and added the ASIO option.... so here's where I stand.
I'm trying to configure V-DJ for wired headphones on the Numark party mix mkii controller. Not using external speakers, need to do ALL mixing in headphones. Need MASTER in headphones until a CUE is selected, then need that in one ear, w/ master in the other. I've had this configured w/ bluetooth headphones in the past, trying now w/ wired headphones to the controller.
For both MASTER & HEADPHONES, my options are:
* CUE LEFT/RIGHT (Numark Party Mix MKII) (WASAPI)
* MASTER LEFT/RIGHT (Numark Party Mix MKII) (WASAPI)
* Numark Party Mix MKII) (ASIO)
For the 1st two (WASAPI) options, the next options are:
* chan 1 & 2
* chan 3 & 4
* chan 5 & 6
* chan 1 (mono)
* chan 2 (mono)
* nothing & chan 1
* chan 1 & nothing
For the Numark Party Mix MKII) (ASIO) option, next options are:
* Master Left & Right
* Cue Left & Right
* Master left (mono)
* Master Right (mono)
* nothing & Master left
* Master Left & nothing
I've tried multiple combinations, and not really getting anywhere. Again, I appreciate any assistance you can provide.
You should use the default audio setup, which is MASTER on CH1+2 and HEADPHONES on CH3+4
Then you should headphone_mix which is an action, to control how much of the decks or the master audio should go to your headphones.
Unfortunately your controller does not have that action premapped on a knob.
However, you can still access the function via the GUI on the mixer panel.
Read the manual here: https://virtualdj.com/manuals/virtualdj/interface/mixer/master.html#headphones
You need to control HEADPHONE MIX
What you're trying to do cannot be done via audio setup
Okay.... still seems to be an issue.....now not getting any audio out to headphones.... neither MASTER or CUE.
SET TO:
MASTER > MASTER LEFT/RIGHT (Numark Party Mix MKII) (WASAPI) > chan 1 & 2
HEADPHONES > CUE LEFT/RIGHT (Numark Party Mix MKII) (WASAPI) > chan 3 & 4
No audio at all.... master or cue from the HEADPHONES jack.... the MAIN jack is feeding the master mix, but we're not using that.
As for the ACTION on headphone_mix, I've never altered anything in here. Is it easy? Can you point to a tutorial, or some basic instructions?
I also see the headphone MIX knob in the GUI, but that's not changing anything for me. Thoughts!
Thanks....
Can ANYONE help me further with this? The previous reply has left me with even more questions and no futher along to resolve my issues... do I need to reach out to Numark?
I am bumping this ONE more time.... I have been given instructions several times on how to set this up for all mixing in headphones.... I have followed them to the letter... .and still NOT WORKING.. Everytime I try to reach out to support, they send me the same instructions without reading in my reply that ITS NOT WORKING, and they repeat the same instructions again. SO... here we go AGAIN!
This really hasn't helped as Im getting ZERO audio to headphones.
I tried two different settings under the default WASAPI settings (see attached pics,) and had the MIX set to mid point to hear any audio. NEITHER of those WASAPI settings brought any audio (mix or cue,) to the headphones jack. Nothing. Headphones are fine, work perfectly. My next thought was faulty headphones jack on controller, but making changes to ASIO settings for audio (see 3rd attached Pic) at least proved that wrong and brought audio to headphone jack, only the master mix. I only switched to ASIO to make sure that jack worked. Still stuck.
Any assistance is appreciated.
Andrew
Attachment(s)
