Hi everyone,
I'm using a single Traktor Kontrol D2 to help control Virtual DJ. The manual (https://virtualdj.com/manuals/hardware/ni/d2/layout/deck.html) says the Deck button should swap between all available decks when only a single one is in use (which is what I'm currently working with). However, I can only swap between decks A and C on mine.
The mapping for the button says "invert_controllers". Is it supposed to be another mapping when it's just one controller? Or is there another way to cycle between all the decks?
geposted Wed 01 Oct 25 @ 6:09 pm
I actually solved this a while ago myself. Anyone who is looking to do something similar, here's the mapping script:
action_deck 1 ? DECK 2 assign_controller "Traktor Kontrol D2" : action_deck 2 ? DECK 3 assign_controller "Traktor Kontrol D2" : action_deck 3 ? DECK 4 assign_controller "Traktor Kontrol D2" : action_deck 4 ? DECK 1 assign_controller "Traktor Kontrol D2"
geposted Sat 18 Oct 25 @ 2:45 am
