Hello,
when I change the KEY of a track using the KEYCUE pad (either on the skin or on the controller) the track always restart from the beginning. Is there a way to do that "on the fly" continuing the playback without restarting? Thanks!!
geposted Sun 02 Nov 25 @ 4:25 pm
The Keycue page works with the last cue point you hit since the track was loaded. If you didn't hit one, there is no last cue, so it goes to the beginning.
Edit: you can select the cue to use from holding down shift on a controller or right clicking a pad with a cue while on that page. However it still works with a set hotcue (which is why it is named Keycue).
geposted Sun 02 Nov 25 @ 5:48 pm
