Topic: File location question
I moved a song from google drive to the C drive and deleted it from google drive. When i open the tag editor, the song has googledrive on the first line and the C: drive on the second line. Why does the tag have googledrive on there when the song is not located there?
Thanks!
geposted Fri 07 Nov 25 @ 12:02 pm
Did you move the file within the VDJ browser or did you use Windows explorer?
Are you using the Cloud Drive feature?
Yes and yes. Thanks!
