Topic: Scratching Numark Mictrack Pro II
Somehow I lost the scratching ability on the controller in VDJ - the Scratch button is on, but moving the jogwheel just changes the pitch of the track, does not scratch. on the other deck the scratch generally works, but it's intermittent at times. vinylmode is on on both decks (this is controlled by the Scratch button anyway).
Is there a way to test if this is a software or hardware issue? Otherwise jogwheels work fine, they adjust the pitch, when the track is not playing I can move it back and forth etc.
or maybe it needs resetting, I don't know how...
I have Virtual DJ 2025 mac built 8909
geposted Sun 07 Dec 25 @ 10:25 am
