Topic: Stems engine GPU failed.
Stems engine GPU failed. m1 error Unable to load model: file:///Applications/VirtualDJ.app/Contents/Resources/model3.mlmodelc/. Compile the model with Xcode or `MLModel.compileModel(at:)`.
Fallback to no stems separation (GPU not available)
Anyone know how to fix this?
I have a brand new macbook M4; I have reinstalled virtual DJ many times; I have cleared Aplication Data; and I made sure SIP is on but sitll no luck?
geposted Tue 09 Dec 25 @ 9:51 am
Did you use something like Time Machine or Migration Assistant to move to your new laptop?
I believe that will break the GPU drivers
Yep I transfred it from my old mac air to the new pro
Any idea how to reset the drivers?
Unfortunately it's an issue on Apple's side with encryption keys. You need to set up the new Macbook as a fresh install.
