Topic: NDI questions
I'm trying to send the VDJ output via NDI from a 2021 M1 Max Macbook Pro.
The receiver is a Yolobox Extreme, which I use for streaming.
The Yolobox sees the NDI feed on the network, but fails to add it and tells me to check the stream codec.
What kind of NDI is SEND-NDI sending, and is there a way to configure it?
I'd like to send HX3 with h.265 since all the devices are on WiFi and I need to keep bandwidth down. I already have the resolution down to 720p.
Is the audio sent over NDI as well? If not, what is the best way to wirelessly get audio to the yolobox that syncs with the video?
geposted Tue 09 Dec 25 @ 6:22 pm
