Topic: Sound quality
My DDj Rev-1 is still having BAD sound Issues after NEW macOS Tahoe came out.
geposted Sat 13 Dec 25 @ 7:32 pm
0.3 ms latency seems a bit low, perhaps try to increase it
how you increase the bit ?
The latency value is in samples. You can click the X on the right side to reset it, or try 256 or 512
i did 50+ sound better... ThankYou
