Topic: VDJ 2026 FX + parameters (database)
Hi fellow DJs
Yes — but on VirtualDJ forums, the only reliable way to get real bullet points is still the BBCode list tag. What you can do (so you don’t see the “
  • ” style and you just see bullets) is to use plain text bullets and avoid [list] entirely.
    Here’s the same post format using plain bullets • (no [list], no
  • [*], no brackets):
    VirtualDJ FX quick reference: key parameters (from UI screenshots)
    I’m building a community reference list of FX and their key UI parameters so scripting/programming is faster.
    Important: the numeric values shown in screenshots are NOT “the correct values” — they’re just examples. What matters is the parameter name + slider index + unit (%, bt, Hz, dB, on/off, etc.).
    Notes
    • Beat unit is bt (beats).
    • Selectors (Pattern/Mode/Scale/etc.) often don’t show all options in the UI, so the full option list/range may be unknown here.
    • Known signed ranges (confirmed/visible):
    • Filter Position: -20 Hz → 15000 Hz
    • Stems bands: -100% → +100%
    • Typical scripting pattern (example):
    effect_active ‘Echo’ on & effect_slider ‘Echo’ 1 50% & effect_slider ‘Echo’ 2 1bt
    Effects
    Backspin
    • #1 Strength — %
    • #2 Length — bt
    Beat Brake
    • #1 Strength — %
    • #2 Pattern — pattern (selector)
    • #3 Bars — bars (selector)
    • #4 HPF — mode (toggle/selector)
    Buttons/toggles:
    • Quantize
    BrakeStart
    • #1 Length — s
    Buttons/toggles:
    • Restart Phase
    Choppa
    • #1 Strength — %
    • #2 Invert — on/off
    • #3 Length — pattern (selector)
    Buttons/toggles:
    • Quantize
    Cut
    • #1 Strength — %
    • #2 Length — bt
    • #3 Duty — %
    • #4 Swing — % (UI shows as R: 00% style)
    Buttons/toggles:
    • Low Cut
    • High Cut
    • Mute Beats
    • Video
    Cyclone
    • #1 Strength — %
    • #2 Length — bt
    • #3 Delay — ms
    Distortion
    • #1 Strength — %
    • #2 Downsamp — x (selector)
    • #3 Bitdepth — bit (selector)
    Down Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    Buttons/toggles:
    • Freeze
    • Reverse
    Ducking Echo
    • #1 Feedback — %
    • #2 Length — bt
    • #3 Color — % (UI can display threshold-style like “> X%”)
    • #4 Reverb — %
    Dump
    (Effect was collapsed in UI screenshot; no parameters visible.)
    Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    • #4 Filter — Hz (cutoff style, UI can show like “<11kHz”)
    • #5 Lowpass — Hz
    • #6 Highpass — Hz
    Buttons/toggles:
    • Reverse
    • Freeze
    Echo Out
    • #1 Feedback — %
    • #2 Length — bt
    • #3 Color — % (UI can display threshold-style like “< X%”)
    • #4 Reverb — %
    Enigma Jet
    • #1 Strength — %
    • #2 Speed — bt
    EQ10
    (Band gain scale in dB not visible in screenshot.)
    • #1 31 — band_gain
    • #2 63 — band_gain
    • #3 125 — band_gain
    • #4 250 — band_gain
    • #5 500 — band_gain
    • #6 1k — band_gain
    • #7 2k — band_gain
    • #8 4k — band_gain
    • #9 8k — band_gain
    • #10 16k — band_gain
    Buttons/toggles:
    • Reset EQ
    • No Profile (selector)
    • Profile Prev
    • Profile Next
    • Profile Add
    • Profile Remove
    FDR Filter
    • #1 Strength — %
    • #2 Type — filter_type (selector; UI example shows LP)
    FDR Pitch
    • #1 Strength — %
    • #2 Type — pitch_type (selector; UI example shows CT)
    • #3 Scale — scale_mode (toggle/selector; UI example shows OFF)
    FDR Ring
    • #1 Strength — %
    • #2 Freq — Hz (UI can display kHz)
    • #3 Mode — mode (selector; UI example shows DECR)
    FDR Roll
    • #1 Strength — %
    • #2 HPF — on/off or mode (toggle/selector; UI example shows Off)
    Buttons/toggles:
    • Quantize
    FDR Tone
    • #1 Strength — %
    • #2 Key — musical_key (selector; UI example shows C)
    • #3 Type — waveform (selector; UI example shows Sine)
    • #4 Octave — octave (selector; UI example shows 6)
    • #5 Scale — scale_mode (toggle/selector; UI example shows Off)
    Filter
    • #1 Position — Hz (signed) (-20 → 15000 Hz)
    • #2 Resonance — %
    Filter HP
    • #1 Position — Hz (HP cutoff; UI can show like “>###Hz”)
    • #2 Resonance — %
    Filter LP
    • #1 Position — Hz (LP cutoff; UI can show like “<#.#kHz”)
    • #2 Resonance — %
    Flanger
    • #1 Strength — %
    • #2 Speed — bt
    • #3 Feedback — %
    • #4 LFO Amp — %
    Buttons/toggles:
    • Tone
    • Phase
    Flippin Double
    (No sliders/knobs visible in screenshot.)
    Buttons/toggles:
    • Video
    Helix
    • #1 Strength — %
    • #2 Length — bt
    • #3 Time — %
    • #4 Speed — %
    Buttons/toggles:
    • Low Cut
    • High Cut
    Hold Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 High Pass — on/off or mode (toggle/selector; UI example shows OFF)
    LFO Filter
    • #1 Strength — %
    • #2 Length — bt
    • #3 Resonance — %
    • #4 LFO Amp — %
    Buttons/toggles:
    • Tone
    • Phase
    Loop Out
    • #1 Length — bt
    • #2 Count — count (selector)
    • #3 Mode — mode (selector; UI example shows Step)
    • #4 Mode Para — %
    Buttons/toggles:
    • Video
    • Stop
    • Slip
    Loop Roll
    • #1 Strength — %
    • #2 Length — bt
    • #3 Duty — %
    • #4 Swing — %
    Buttons/toggles:
    • Video
    • Low Cut
    • Hi Cut
    Low Cut Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    • #4 Swing — %
    Buttons/toggles:
    • Reverse
    • Freeze
    Matrix
    • #1 Strength — %
    • #2 Length — bt
    • #3 Duration — bt
    Buttons/toggles:
    • Quantized
    • 3/4 End
    MergeFX
    • #1 Strength — % (UI can display threshold-style like “> X%”)
    • #2 Slot — slot (selector)
    Buttons/toggles:
    • Cancel
    • LED
    Mobius
    • #1 Strength — %
    • #2 Length — bt (knob/selector)
    • #3 Echo — %
    Buttons/toggles:
    • Saw
    • Reverse
    Mobius Saw
    • #1 Strength — %
    • #2 Length — bt (note: negative bt values possible; UI example shows -1 bt)
    • #3 Echo — %
    Buttons/toggles:
    • Reverse
    Mobius Tri
    • #1 Strength — %
    • #2 Length — bt
    • #3 Echo — %
    Buttons/toggles:
    • Reverse
    MT Delay
    • #1 Strength — %
    • #2 Length — bt
    Buttons/toggles:
    • Trailing Stop
    Mute
    • #1 Strength — %
    Noise
    • #1 Position — Hz (UI example shows very low, like “<20hz”)
    • #2 Wet/Dry — %
    Pan
    • #1 Strength — %
    • #2 Length — bt
    • #3 LFO Amp — %
    • #4 LFO — % (UI displays %; likely rate/shape/amount)
    Buttons/toggles:
    • Low Cut
    • High Cut
    Phaser
    • #1 Strength — %
    • #2 Speed — bt
    • #3 Feedback — %
    • #4 Stage — % (UI displays %; often corresponds to stage amount)
    Buttons/toggles:
    • Tone
    • Phase
    Ping Pong
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    • #4 Filter — Hz_or_mode (UI example shows OFF; may behave as cutoff/mode)
    Buttons/toggles:
    • Reverse
    • Freeze
    Pitch
    • #1 Strength — %
    • #2 Pitch — %
    Buttons/toggles:
    • Low Cut
    • Hi Cut
    Pitch Down
    • #1 Strength — %
    • #2 Length — bt
    • #3 Tail — count (integer-style)
    Buttons/toggles:
    • Quantize
    Pitch Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 Pitch — %
    • #4 Feedback — %
    Buttons/toggles:
    • Reverse
    • Freeze
    Pumper
    • #1 Strength — %
    • #2 Length — bt
    • #3 Offset — beat_fraction (UI example shows fractions like -1/16)
    • #4 Depth — dB (negative values possible)
    Buttons/toggles:
    • Quantize
    Recycler
    • #1 Strength — %
    • #2 Length — bt
    • #3 Resonance — %
    Rev Delay
    • #1 Strength — %
    • #2 Length — bt
    • #3 Swing — %
    • #4 LR Ratio — % (signed values possible)
    Buttons/toggles:
    • Low Cut
    • High Cut
    Reverb
    • #1 Strength — %
    • #2 Decay — %
    • #3 Room Size — %
    • #4 Brightness — %
    Buttons/toggles:
    • Low Cut
    • Hi Cut
    Rider
    • #1 Strength — %
    • #2 Length — bt
    • #3 Pattern — pattern (selector; UI example shows MAJOR)
    Buttons/toggles:
    • Quantize
    Riser
    • #1 Strength — %
    • #2 Length — bt
    • #3 Speed — count (integer-style)
    Buttons/toggles:
    • Quantize
    Scale Down
    • #1 Strength — %
    • #2 Length — bt
    • #3 Scale — scale_mode (selector; UI example shows MAJOR)
    Buttons/toggles:
    • Quantize
    Scratch DNA
    • #1 Select — index (selector; UI example shows Select 1)
    Buttons/toggles:
    • Editor…
    • Over
    • Quantized
    Slicer
    • #1 Step Size — bt
    • #2 Length — bt
    • #3 Slice — index (1–8 pads visible)
    Buttons/toggles:
    • Lock
    • Video
    Slip Roll
    • #1 Strength — %
    • #2 Length — bt
    • #3 Duty — %
    • #4 Swing — %
    Buttons/toggles:
    • Low Cut
    • Hi Cut
    • Video
    Spiral
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    • #4 Pitch — %
    Buttons/toggles:
    • Low Cut
    • Hi Cut
    Stems
    • #1 Vocals — % (-100 → +100 %)
    • #2 Kick — % (-100 → +100 %)
    • #3 Instru — % (-100 → +100 %)
    • #4 Bass — % (-100 → +100 %)
    • #5 HiHat — % (-100 → +100 %)
    Stretch
    • #1 Position — %
    • #2 Length — bt
    Stutter Out
    • #1 Strength — %
    • #2 Pattern — pattern (selector; UI example shows Pat 3)
    • #3 Bars — bars (selector; UI example shows 3 bars)
    Buttons/toggles:
    • Quantize
    Up Echo
    • #1 Strength — %
    • #2 Length — bt
    • #3 Feedback — %
    Buttons/toggles:
    • Reverse
    • Freeze
    VinylBrake
    • #1 Strength — x (multiplier)
    • #2 Length — bt
    • #3 Echo — on/off
    • #4 Repeat — on/off
    Buttons/toggles:
    • BPF
    Wahwah
    • #1 Strength — %
    • #2 Speed — %
    • #3 Frequency — %
    • #4 Width — %
    Buttons/toggles:
    • Lock
    • Shape
    • Reset Phase
    If anyone wants to help, reply with missing FX pages and I’ll keep extending this list.
    geposted Sun 14 Dec 25 @ 1:29 pm
    how to change beatgrid fx param ? what are the default beatgrid param ? can you please
