v2026-m b8950
after playing for about 3 hours deck 4 allows loading of songs but no audio output is sent to the controller. using decks 3 and 4 in a two dj setup. Issue is resolved with an application restart
geposted Sun 14 Dec 25 @ 1:48 pm
Following. I am experiencing the exact same thing. I am using Windows 11 and the latest VDJ2026. I am using a DJ2Go2 for control only. The audio is going from PC to mixer via USB. Other deck plays fine just in the OP. Restarting VDJ fixes it for the remainder of the set.
geposted Thu 25 Dec 25 @ 12:12 am
I was able to fix a similiar issue.
If using an effect like VinylBrake or Echoe out or Backspin, check if the effect turns off afterwards. I often use BrakeStart wich behaves differently when the effect is turned off.
If this sounds like you, there is a setting in the options resetFXOnLoad that you may want to enable.
geposted Fri 16 Jan 26 @ 5:01 pm
