I Just Try The new Fluid Beatgrid i was playing at a birthday party, and Suddenly the tempo of that song I had made Variable Tempo started to slow down, I suddenly grabbed the tempo fader to speed it up but it didn't work, neither did it speed up nor slow down, I hope the technicians see this
geposted Wed 18 Feb 26 @ 9:54 pm
I´m in Germany. Latest update but another BPM window.
No Fluid Beatgrids!
No Fluid Beatgrids!
geposted Sat 21 Feb 26 @ 4:05 am
I've tried the early acces. I use some medleys for performing (with various BPM) and tested one. It calculates it perfectly, without having to manually set things. Also on sloppy Disco tracks, the BPM and beats that sent OS2l that trigger to DMX software seem to be spot on every attempt.
I do not know if the BPM is more equal (as desired for mixing) or if it's just a variable BPM but when running DMX Chases, they are never off. Tested various disco tracks.. awesome!! Can't wait for the official update to be released.
geposted Wed 25 Feb 26 @ 10:39 pm
After setting a few anchor points, I wanted to set another one near the beginning of the song. Suddenly, it acquired an unrealistically high tempo. It also could not be removed. The only option left was to ‘Delete all anchor points’.
I attempted this three times, each time with the same error...
geposted Sat 28 Feb 26 @ 9:06 pm
