Topic: History Folder Recurse
Is there a way to turn off the recurse on the history folder?
If I left or right click on the history folder, whether by accident or intentionally, it will recurse the entire folder of 10s of 1000s of songs which will freeze the skin for sometimes up to 30 seconds. Music still plays. There is no right click option to uncheck recurse. There doesn't seem to be any setting in Options to disable it.
geposted Sun 21 Dec 25 @ 5:13 pm
NVM. I found it. It''s in the Properties box of the History folder. Shouldn't it be in the right click options like most other folders?
