Topic: VDJ 2026
Never mind, just going back to VDJ2025. I have zero need for AI-enabled features, they're a waste of hardware.
geposted Fri 02 Jan 26 @ 1:51 am
Well I suppose if you never plan to upgrade your controller again, you'll be fine.
Are you not using the stem separation either?
Also none of the new features add any additional local processing.
And the lyrics on wave can simply be turned off as well, so not really any reason not to update
Yeah I recently checked CPU use on my laptop with both 25 and 26 and it's exactly the same. No additional resource required.
