Hello! I have a USB drive I use formatted in the CDJ Export Format. I regularly plan sets and do library management on my main Windows 10 Desktop. I'll then transfer music and cue points via this USB to then use on either Pioneer Equipment or my performance laptop, an M1 Macbook Air. After this most recent VDJ update, my USB has started disconnecting itself from the Mac once VDJ opens and starts parsing the USB drive. I starting getting this issue after the most recent update of VDJ, and I have no issues with the drive on my Windows 10 Desktop or Pioneer Equipment. I also updated the Macbook to the most recent version of MacOS and it has not resolved the problem.
Is there some way I can fix this problem? I haven't found any posts about this problem elsewhere.
geposted Sun 11 Jan 26 @ 9:28 pm
