Hello! I have a In SearchDB = 0 filtered list (about 6793 files) and I want to remove those files from database. I have tried to select all the files and remove from search db but no success on that. Some files have obsolete path (on a NAS or on a Windows laptop or on clouddrive/googledrive or Tidal, Deezer, local cache etc). I want to clean-up the database because of my other issue I've posted about vdj restarting when loading some files (many of them marked as not found - the red X icon but some of them are not marked as not found, they have the green downloaded to cache icon).
I moved to lists for some time and I'm still struggling to understand the database structure and the way vdj manages the lists when using clouddrive (google drive) for synchronization. For the start I would like to be able to clean the database using the tool inside the vdj software. Thanks.
I'm using a Macbook M1 Max v2026-m b9004 but the behavior is the same on the Windows laptop.
geposted Sun 15 Feb 26 @ 7:46 pm
