Topic: Fluid beatgrid in CDJ export
Is it possible to export a track "analyzed and corrected" with fluid beatgrid to CDJ export?
geposted Fri 06 Mar 26 @ 6:02 pm
The export with the precise grid should already be possible.
Stabilized export would be a good add-on, both to CDJ and in general.
+1
@vinyl what do you mean by precise grid?
I use CDJ export a lot but my thought was if a "corrected track in terms of fluid beat grid" was able to be exported aswell?
But I guess that's what you mean by "add-on" ? taking it's not possible today then.
Yea the stablized export (warp) is what I believe is not possible. Export with proper beatgrid should already be.
Adion or anyone else from VDJ, would it be possible for you to add a feature to be able to export a stabilized fluid beatgrid so it can be played through CDJ export?
