Topic: Unwanted Auto Mix Populate on Karaoke Singer
Using the left hand search box to search for regular singers and there song. If search and double click the name it will overwrite my automix list and populates with the selected singers songs. This is not ideal at a live event as I lose my upcoming tracks to be played. I know now not to double click however I have done this a few times accidentally. I cant see why anyone would want this to happen. Please note this only does this if you have searched and selected using the recently added search function. If you scroll and look for the singer without using the search bar and then double click then the overwrite does not happen. This happens on both of my windows 11 laptops which uses versions b9209 and b9005. Both laptops run with i7 and 16gb/24gb of RAM.
Thank you
geposted Sun 08 Mar 26 @ 12:37 pm
