Hi
I know there have been issues with nVidia drivers recently but thought safe video decode etc solved the problems, however I just updated to the latest drivers and altho everything seemed OK, when I went to run 'shader' it suddenly disappeared, then when I closed the VDJ, the video window hung, I can force close it but afterwards when I load VDJ, if I turn on video the program hangs, the only solution is a restart before running VDJ again.
Is this a known issue (with a possible solution), or is it unique to me.
Anyway I've rolled back the drivers to September last year, if it is a known issue and there is a proven last version drivers that work please let me know.
Thanks
Thanks
geposted Sun 08 Mar 26 @ 5:37 pm
Just experienced the problem after a clean install of older drivers so any help would be appreciated, I did a DDU to remove all nVidia drivers then installed the version I am sure I was running previously and altho VDJ runs smoothly the first time, the video window isn't closing after and I cannot then run the program again!
geposted Sun 08 Mar 26 @ 6:28 pm
After a complete wipe and reinstall, the issue persists with old video drivers and on further investigation the problem is something to do with my Denon controller. I have posted a separate message regarding this so as not to confuse the issue.
Please consider this topic null and void.
geposted Wed 11 Mar 26 @ 1:55 pm
