Hi, i config custom button for changue the beatgrid mode, when use reanalyze fluid get fluid mode, when use reanalyze multi get fluid (fast), but the fast option isn´t aviable on all tracks. can some one tell me why analyze multi don´t work for all tracks?
thanks
thanks
geposted Fri 13 Mar 26 @ 5:26 am
another question, sometimes in bpm edit window can see a star on fluid button... and i ignore what means....
thanks
thanks
geposted Fri 13 Mar 26 @ 7:02 pm
The star is there to show which type of analysis VDJ recommends.
geposted Fri 13 Mar 26 @ 7:05 pm
thanks,, perhaps the tracks that can use the fast mode is because they had a variable analysis of the previous version. If some one can confirm it, i appreciate.
Regards
Regards
geposted Fri 13 Mar 26 @ 8:14 pm
