I’m encountering a problem when I create an "effect_select_popup" command for FX2. When I turn the knob to navigate through the list, the knob does affect the effects list, but it controls the FX1 list instead of FX2.
geposted Thu 19 Mar 26 @ 7:00 am
effect_select_popup 2
include the slot number
geposted Thu 19 Mar 26 @ 10:21 am
thank you, it's work :)
geposted Thu 19 Mar 26 @ 10:03 pm
